September 19, 2024
How the TNC7 helps overcome common CNC control challenges
While machine tools have long been the focal point of standardization efforts, the spotlight is shifting toward CNC controls. This shift is driven by the need for greater flexibility, faster production times and more sophisticated machining capabilities. In this blog, we explore the common challenges that can make or break productivity, and how HEIDENHAIN’s advanced TNC7 and TNC7 Basic controls can help overcome them.
Challenge 1: The Skills Gap
The growing skills gap in manufacturing is a well-known issue. As experienced operators retire, there’s an increasing need to train new workers quickly and efficiently. However, the complexity of traditional CNC controls can be a barrier, leading to longer training times and reduced productivity.
What to consider
The TNC7 addresses the skills gap head-on with its intuitive and user-friendly interface. The control is designed to be task-focused, allowing operators to customize the home screen with their specific favorites. This personalization reduces the learning curve for new users, enabling them to perform advanced tasks more quickly. The TNC7 also includes process videos built into the control, guiding users through simple tasks and making it easier for new operators to get up to speed.
Challenge 2: Machine Crashes
Machine crashes are costly and time-consuming. The consequences can range from damaged parts and equipment to significant downtime. Traditional methods of avoiding crashes often involve manual checks and extensive operator oversight, which are prone to human error.
What to consider
HEIDENHAIN’s TNC7 offers advanced protection against machine crashes through two key features: Digital Twins and Dynamic Collision Monitoring (DCM). The Digital Twin technology allows operators to simulate the machining process in a virtual environment before running the actual machine, reducing the risk of errors that could lead to crashes.
Additionally, DCM takes collision protection to the next level by monitoring the tools, machine components and workholding equipment. The system uses accurate 3D models and smart probing functions to guide the operator, ensuring the fixture is correctly positioned and significantly reducing the risk of collisions.
Challenge 3: Intuitive Control Interface
Many CNC controls are not as intuitive as they should be, which can lead to frustration and inefficiencies. A complicated control interface can slow down even the most experienced operators, impacting overall productivity.
What to consider
The TNC7 excels in providing an intuitive user experience. The layout is simple and user-friendly, designed with a focus on task efficiency. Operators can easily edit their home screen to include their most-used functions, ensuring that everything they need is just a touch away. The TNC7’s multi-touch operation is fluid and responsive, allowing operators to work more naturally and efficiently. This ease of use is further enhanced by the TNC7’s graphical programming feature, which enables users to draw contours directly on the touchscreen. The control then converts these drawings into a Klartext program, simplifying the programming process and reducing the time spent on repetitive tasks.
Challenge 4: Customizable Workflow
One of the limitations of many CNC controls is the inability to customize the workflow or work screens to individual operator preferences. This lack of flexibility can lead to inefficiencies and reduced job satisfaction, especially in environments where multiple operators share the same machine.
What to consider
The TNC7 offers extensive customization options, allowing operators to tailor the control interface to their specific needs. Users can create individual profiles with personalized settings to optimize workflows for their tasks. This is crucial in environments where CNC machines must handle a wide variety of tasks and requirements. By allowing each operator to configure their interface, the TNC7 ensures that the control is as efficient and user-friendly as possible.
Challenge 5: Time Efficiency
Time is money in manufacturing, and wasting time on repetitive tasks, such as reposting simple 2-axis code, can significantly impact productivity. Operators often have to switch between the machine and their computer to make adjustments, leading to lost time and potential errors.
What to consider
The TNC7 combats time wastage with its smart programming capabilities. Operators can import a contour into the workspace and make necessary adjustments directly on the control, without needing to return to their computer. This feature streamlines the workflow, reducing the time spent on repetitive tasks and allowing operators to focus on more complex and value-added activities.
Challenge 6: Probing Methods
Probing is a critical aspect of CNC operations, but it can also be one of the most complex and challenging. Each CNC control has its unique probing methods, and mastering these can be time-consuming and frustrating for operators.
What to consider
The TNC7 simplifies probing with its smart probing functions, which offer graphical guidance in sync with the real probing environment. This feature ensures that operators have a clear understanding of the probing process, making it easier to achieve accurate results. The graphical support provided by the TNC7 reduces the likelihood of errors during probing, enhancing overall machining accuracy and efficiency.
Stay ahead of the market
Overcoming common CNC control challenges is key for maintaining productivity and competitiveness. HEIDENHAIN’s TNC7 and TNC7 Basic controls offer intuitive interfaces, customizable workflows, advanced safety features and smart probing functions, directly addressing issues like the skills gap, machine crashes and time efficiency. By adopting these advanced controls, manufacturers can streamline operations, reduce costs and enhance output quality tostay ahead in a complex and evolving market.
Interested in learning more? Contact us today to discuss how the TNC7 can enhance your operations.
Want to dive deeper into the capabilities of the TNC7? Download our e-book for more insights.
Ready to see the TNC7 in action? Inquire about a product demo and experience its advanced features firsthand.
Written by: Joe Pizzoferrato—TNC Product Specialist & Application Engineer
With 12 years of experience in the CNC machining industry, Joe Pizzoferrato provides invaluable expertise when it comes to 5-axis machining, particularly in high-precision accuracy applications. He graduated from Northern Illinois University in 2009 with a bachelor’s degree in Mechanical Engineering. Joe’s solid technical background and hands-on approach make him a trusted professional in the field, always focused on delivering top-tier results and advancing machining techniques.
